I dont like the looks of this
Could be a water pump also, Coolant tends to blow around as you drive, You can never be sure where a leak based on where is wet.
Pressure test is your best bet for finding the leak.
Hbr fr8 sells a nice coolant pressure tester. It comes with all the adapters for different cooling systems. It will pay for itself if you compare what a shop needs to charge for a test.It has saved Me a lot of time and guessing.
