Hypertech Programing
Old 01-21-2007 | 12:48 PM
JaySan's Avatar
Default Hypertech Programing
I just bought a Hypertech Programmer for my 2000 Camaro (3.8L) automatic transmission and I would like to know if any one else has done this wit their car. I would like some information on what is the best shift points for myautomatic transmissionand what percent is best for the transmission firmness ? I looked at the Hypertech website and didn't find much information. Thanx in advance
Old 01-21-2007 | 11:55 PM
WMadam11's Avatar
Default RE: Hypertech Programing
What the hell is a Hypertech Programmer? lol
Old 01-22-2007 | 12:30 AM
JaySan's Avatar
its a handheld computer chip upgrade
Old 01-22-2007 | 12:31 AM
shnormo's Avatar
Shift past red line cuz it can handel it and then if you like firm shifts, max it out.
Old 01-22-2007 | 12:47 AM
JaySan's Avatar
Well right now its programmed to shift at 6,000 rpm . Should I go to 6500 rpm? And where should I program the first,second and third shift points ?
Old 01-22-2007 | 01:04 AM
Be careful not to set the shift points past the rev limiter, because it will never shift gears at WOT. That engine really does nothing past 6000 RPM, except make more noise, unless you made some major mods.
Old 01-22-2007 | 02:22 AM
JaySan's Avatar
What is "WOT" and my mods are 160 degree thermostat, flowmaster exhaust, SLP cold air intake , Whisperlid , Fram air filter and I am about to install a SLP smooth rubber bellow ,
Old 01-22-2007 | 03:35 PM
WOT= wide open throttle=pedal to the metal.
You have some good useful mods which increase torque, but do not change the point at which the engine peaks, so when you rev it too high the heads and cam still restrict the power output, so you want to shift to the next gear before that happens.
Old 01-22-2007 | 07:52 PM
JaySan's Avatar
so i should leave the automatic transmission stock and dont mess with the shift points ?
Old 01-22-2007 | 11:20 PM
You can change them, but make sure that you don't set them higher than the speed limiter. Actually you may stay about 200 RPM lower than the limiter. You can also chenge the limiter setting, but you run the risk of engine damage.
