How hard to replace power window motor in 96 Camaro
Old 07-19-2007 | 12:41 PM
gearyr's Avatar
Default How hard to replace power window motor in 96 Camaro
I have a 96 Camaro with power windows. The drivers side is not working. Bought a new power window switch. The only window working is the passenger side. Checked the fuse. Fuse good. The window motor has been replaced before on the drivers side. The drivers side window will not go up or down. Need help. Thanks, gearyr.
Old 07-19-2007 | 09:03 PM
bluovlh8er's Avatar
Default RE: How hard to replace power window motor in 96 Camaro
i had a hell of a time tring to replace mine. it can be done though.
Old 07-20-2007 | 05:57 PM
Pro_built7's Avatar
its very easy man, buy a new motor of ebay, then do a search on this site, you have to drill holes through the inside door skin in order to drill out the rivets holding the motor on. then the new motor has small bolts, just find the right installation instructions, very simple fix.
Old 07-29-2007 | 01:17 PM
SteveR's Avatar
You may not have to drill the rivets, I replaced both of them. On one window the motor was held in by nuts already. But on the other it was riveted. One word of advice, be sure you are drilling the rivets that hold the motor and not the bracket mechanism.
Old 05-10-2008 | 01:25 AM
whatsupdoc's Avatar
Deleted.
Old 05-10-2008 | 09:46 AM
98SS#689's Avatar
Here's a link I used when I changed mine. Very easy. Pull your door speaker to make things more accessible behind the door skin.
http://shbox.com/page/windowmotor.html
Old 05-21-2008 | 11:11 PM
JesusFreak's Avatar
98SS#689
Thanks for the post. It really helped with the replacement of the motor.
cornmuffin
07-24-2014 10:22 AM
Triangle12
04-21-2012 08:11 PM
Slick6
11-01-2011 10:54 PM
craby
09-01-2011 11:48 AM
z28pete
08-04-2006 11:04 PM
Quick Reply: How hard to replace power window motor in 96 Camaro
