high idle
i have a 93 3.4 and i have a high idle problem about 2000rpms and it s all the time and i have replace the iac and the tps and cleaned the trottle body what else could there be? and can loose injectors cause the vacum leak
Yes, along with poor running. Also check all throttle cables, including TV cable, and Cruise Control cable. Make sure the throttle valve fully closes and that stop screw was not maladjusted. Also, brake boster cam be a source of major vacuum leaks.
yup thats what i heard. just dont do it on a hot engine ya know? BOOOM!
