high beams
i have a 94 camaro. and the high beams just dont work at all. i was told to check the fuse but the funny thing is i cant find the fuse at all! ive looked at the fuse boxes and none of em have a highbeam fuse. i even looked through the chiltons manual and cant find out where it is. can somebody please help me? cant get my safety check without the high beams working.
There are no headlamp fuses, but there is a circuit breaker built in into the headlight switch. Low beam is fed directly by the headlight switch. Power for the high beams also comes from the headlight switch, but then it goes to the dimmer switch and then to the lamps. Check the dimmer switch.
sorry guys, i feel stupid for asking all these questions. ok just so im sure, where exactly is the dimmer switch for the headlights? i thought it was that switch on the left side next to the switch to turn the headlights on.
