Help with Vacuum hoses
Old Jun 20, 2009 | 06:36 PM
vjfelix28's Avatar
Thumbs down Help with Vacuum hoses
I just put new valve cover gaskets on my all stock 3.4. putting everything back, ive run into a problem. theres two vacuum hoses that i cant figure out exactly where they go. one is from the fuel lines, its in the same group of three. the other is a small odd shaped hose that i believe goes in the grommet on the plenum and somewhere towards the right side of the bank. I also dont kno if one of them connects to the map sensor. I really need help with this. Ill get some pics up if that would help? btw 95 camaro.
Old Jun 20, 2009 | 10:50 PM
osduck5's Avatar
You should have a Vehicle Emissions Control information label somewhere under the hood. Mine is on the black plastic sheild above the fans. The haynes manual does not show a pic of the vac lines. I use a cheap digital camera and take pics of everything before I start disconnecting, that way, I can always go back and see where things were. Sorry I am no help.
Old Jun 21, 2009 | 05:13 AM
vjfelix28's Avatar
thats what i should've done...
thanks anyways,
anyone else?
gdhurst
Apr 27, 2014 07:48 AM
dcsosro
Oct 31, 2011 09:58 AM
96 3.8L Texas
Oct 21, 2010 11:58 AM
bizarre660
Apr 6, 2008 04:07 PM
Zero
Dec 8, 2005 03:39 PM
