Help,,stumbling,backfire??
93 3.4 v6 auto,just bought this car and it has a problem(hopefully not major)idle is perfect-casual driving it wants to stumble and backfire through tb,but when i step on it it will power up and take off..i was told its like its flooding because you can stand behind car and get it to act up and your overtaken with fuel smell through exhaust,,replaced parts so far are,,map sensor,crank sensor,cam sensor,coolant temp sensor,egr,fuel filter,tps,new plugs and wires,coil packs and moduel,,,check fuel pressure its 40psi,,regulator works-pulled vacuum hose off and pressure increased to 45psi,,,no vacuum leaks found,,only codes were 36 , 24 , 93,,where do i go from here?????
