Help!! Car is stuck at school
Old 10-07-2008, 06:24 PM
Spartan66's Avatar
Default RE: Help!! Car is stuck at school
I watched some idiot on a cell phone pull up to a diesel pump start pumping then about a minute later realized he was pumping diesel into his PORSCHE... so its not too uncommon for anyone i suppose.
Old 10-07-2008, 06:32 PM
MusicMan's Avatar
The Jazz Man
I've seen people put diesel in the wrong car also.
Old 10-07-2008, 08:16 PM
sledhed32's Avatar
Take a crow bar or somthing and hit the bottom of the fuel tank and try to start it. That may get you home and temporary fix.
Old 10-07-2008, 08:21 PM
Failed Devices's Avatar
If it doesn't turn over I would check the battery connections. I had a problem where I would attempt to start mine and it wouldn't do anything. I found my battery terminals to have corrosion all over them. All it took was for me to wipe them off.
Old 10-08-2008, 04:26 PM
SilverBullet5's Avatar
Well I had it towed to a shop after class last night and they started it up this morning no problem, it was low on oil and I def. did not pump diesel into it, I use the same gas pump everytime but thanks for all the input and helpin me figure out the problem.
Old 10-08-2008, 07:26 PM
RSSteve's Avatar
its never good when a car fixes itself. There was something that made it do that and it may again.....
Old 10-08-2008, 09:39 PM
sledhed32's Avatar
I SECOND STEVE
AntsToy
08-19-2011 01:57 PM
Shalamara
70-81 Transmission & Differential
08-15-2011 03:55 PM
JG69
03-20-2011 12:16 AM
Potterboy
01-24-2010 11:38 PM
Quick Reply: Help!! Car is stuck at school
