Help!!!!
Hey guys whats up,
somewhere a little while back, I posted about a rear end clunk/rattle noise.Well I cant find it so im starting a new one.
Ive got a video and some pictures of the noise im hearing. Its the rear driver side wheel hub
http://s667.photobucket.com/albums/vv36/mstephens22/
I know this is a moving part so ofcourse its gonna me some noise but, should I hear it while driving or coasting. Im not sure how to take it apart past what I have already done so im kindof stuck.If anyone could give any input id appericate it
Bad brakes?????? I have the brakes off.
also so i can understand a little better till i get a manual does the part in the video or picture tht im shaking come off the axle or is it all on peice. I need to get a manual so i can find where all the axle bearings are located.
The sound almost sound more like you have some play in the ring and pinon gears than the axle bearing.
I would do a real good inspection of the universal joints on the drive shaft to before tearing into the axle. Hard to diagnois without feeling or hearing it as the car is moving with weight on the axle.
The part in the video is the axle shaft. It is all one piece. To remove it, according to my repair manual, you must remove the differential cover and remove the locking C clip. Then to remove the axle from the housing, you will need a slide hammer and a bearing puller. Sometimes, when the bearing is going bad, or is bad, you can feel it kinda grinding or rolling rough if you turn the axle by hand.
Its not always making that noise when I drive or, I would go crazy but, only when turning left with out throttle.
How hard is it to change the universal joints on the drive shaft. Is it just unbolt and bolt back up with new u joints?
I ask cause sometimes theres a slight clunk when breaking or taking off and im thinking maybe its worn u joints or if not its something loose or worn in the differential...
Thanks for the replys ...im tryin to get to the bottom of this
After going back and reviewing the video one more time, I'm goiing with Craby's and ZZpetes diagnosis, bearing. For some reason, the first time I watched it, I was thinking you were turning the axle right to left but you are moving back and forth.
