having problems... need help
Hey guyz.
I don't know that much about cars and i have a '99 Camaro... well recently i have noticed a wierd sound like a grinding kinda sound wen i start to accelerate. My fren said i might have a hole somewhere... any one could help me on where the possible problem might be? thanks i really appreciate it.
RE: having problems... need help
Grinding? Sounds like your trans is in for major problems -- get it looked at immediately, and check the fluid -- if it is burnt smelling/looking... If your trans is dying, you will likely need it services -- a fluid change will not help long term! When you do the work, put Dexron 6 back in, NOT 3. 6 lasts much longer...
