grinding noise
Old 02-23-2010 | 01:14 AM
1999chevy's Avatar
Default grinding noise
my car sounds like it is grinding where the tranny is but only going up a hill or when there is major tension.but when i push on the gas it stops for a second then starts again.then after it does that for a while it starts doing it in nutral and while it is idleing . Anyone have any ideas on what it is or how to fix it?????
Old 02-23-2010 | 03:43 AM
um... what trany is in it?
Old 02-23-2010 | 10:55 AM
1999chevy's Avatar
it is in 99 v6 camaro and it is an auto
Old 02-23-2010 | 11:39 AM
i would look at the carrier bearing and u joints first.
Old 02-23-2010 | 11:43 AM
resident13's Avatar
does it make the noise when you are sitting still too or only when you are moving?
Old 02-23-2010 | 03:59 PM
1999chevy's Avatar
it makes the sound during both
Old 02-23-2010 | 04:03 PM
osduck5's Avatar
has anything hit the inspection plate pushing it back against the flywheel?
Old 02-23-2010 | 04:16 PM
1999chevy's Avatar
not that i can see but i can double check cause it sounds like gears are grinding and it is coming from the shifter so i know its the tranny
Old 02-23-2010 | 04:21 PM
yah its not the carrier bearing or the u joints if it does it at a standstill. like duck says check to see if the converter cover is lose or damaged and while your down there check to make sure the starter is not lose. maybe take the converter cover off and make sure the converter bolts are tight. whens the last time u had the tranny serviced? need to change fluid in em every 50k or so.
Old 02-23-2010 | 04:28 PM
1999chevy's Avatar
i did the tranny service about 5000 miles ago but i am going to take it to do it again do u that is all it could be?
Quick Reply: grinding noise
