Great...
Great...
so i just got home and noticed my clutch slip the slightest bit (going into 2nd after i let the clutch out it will rev up about 300 or so the drop back to normal)... its only 6000 miles old WTF its never done it like that b4 on this clutch now i know i could have let the clutch out to fast or gave it a little bit too much gas but thats not what it felt like it deff felt the way it did when the first clutch was going bad
Uh-oh! Can't take all the torque of your 3.4?
You could have let the clutch out fast, but it still should grab and not slip no matter what.
When you replaced the clutch, did the pressure plate also get replaced?
EDIT: Was the flywheel replaced too, or at least re-surfaced?
i got it at pepboys my friends gpa is a chevy tech hes the one that told me to get the lux i dont know if it was glazed i dont think so i did go around it with a palm sander and 100 grit paper (friends gpa said it was a good idea)
When I was looking into a clutch for my 3.8 I found dozens of post on other sights of people who had back luck with the stock replacements even the OEM clutches bought from GM. We had a poster on this sight in the last few weeks that had a Delco clutch only make it 5K.
I would never recommend replacing a clutch without a resurface/replaced the flywheel. If there is any blue color, glazing or surface cracks it will cause the new clutch to fail. As a general rule clutches do not have much of a warranty but not surfacing the flywheel will void what they do give.
well this clutch has a lifetime warranty (much like autozones product) soo if it does need replacing its free but if i do need a new one what do you suggest for a brand
I put in the Centerforce dual friction unit. It is basicly the same pressure as stock but they claim 90% increase in holding pressure. I am a big fan of composite clutchs.
