got a question
got a question
i'm hoping this isn't a major problem starting.
96 3800 v6 5 spd.
the problem is starting up. this doesn't always happen just seems happen when i don't need it too. lol
anyway a week ago i had the ac compressor go out, so i bypassed it this friday, an she cranked up fine an ran fine, saturday she cranked right up ran fine.
she sat saturday nite an allday sunday, since i didn't go anywhere.
so come early Monday morning i whent out to go to work 6:25am turn key , turns over an over but no crank. i repeat still no crank, i repeat the i can describe only as a backfire into the air intake (like u hear on an old carb car when it burps back thru the carb)
no crank, so i repeat turn key turns over over then shutters no crank, repeat , turn over turn then shutter an starts shakey then smoothes out. (maybe 5mins it took to start but seems like 4ever)
I drive to work at 65mph on cruise like it never happen. at work i crunk at lunch fired up first lick, after work fired up on first lick,
so any ideas wtf was going on in the morning?
i'm hoping just needs new plugs an wires.
96 3800 v6 5 spd.
SES light has been on since i bought the car 3yrs ago, the only codes i got then when i had it tested was
p1350
p1361
p0130
has cranked fine, up till here recently.an like i said it doesn't always do it.can go weeks an never happen till one day out the blue.
is past due for new wires an plugs an filter, that i plan to do next weekend.
p1350
p1361
p0130
agree scann for trouble codes three yr old codes dont tell whats happening now. check connections to the ignition modual and the crank, cam sensors. if plugs and wires havent been changed in a long while it wouldnt hirt to change.
To avoid confusion..."turns over", "cranked", and "crunk"? all mean the same thing. I hadda decypher what a you was sayin! Now I cod a haddock (a lil humor for craby)!
You going to cook it 69? Lol.
Plugs and wires wouldn't cause no firing at all. Since the engine is turning over.... Unless you magically ****ed up ALL of them at the same time... Even then I don't think you'll completely kill them all.
I suggest checking out the fuel pump. Check your fuel pressure and make sure it is adequate. I think over 50 PSI should be fine. If it's not, I'm gonna say fuel pump.
1970 camaro.. restoration
I have a 1970 Camaro and its in the middle of restoration.. the bodys done and now its just putting everything back into it... I was just wondering what are some things I could buy that could make my Camaro look and sound great.. So far i have a 350 crate moter, orginal rims... orginal dash.. pritty much everythings orginal besides the engine.. I was just seeing if anyone had any good ideas to make this car look great.. I love the the design of the new 2010 camaro and love the interior.. if anyone has any ideas please post a comment.. Thank you all and have a fun time on CamaroFourms
