Got everything installed but still rides the same......
Old 08-26-2010, 09:15 PM
BoricuaHec01's Avatar
Default Got everything installed but still rides the same......
I just got my front upper control arms, upper ball joints, lower ball joints and outter tie rods installed, a wheel alignment and my Maro still rides the same, the steering wheel is real hard when I turn and park and the steering wheel shakes when I go above 50. What is this?
Old 08-26-2010, 09:16 PM
I'm thinking it's the steering pump.
Old 08-26-2010, 09:20 PM
osduck5's Avatar
Could you have a tire out of balance or uneven wear causing the steering wheel to shake. I don't believe the steering pump would cause that, however, it could cause the steering to be stiff. does it whine when you are turning?
Old 08-26-2010, 10:04 PM
Yea, it's really stiff when I turn, it's literally a work out. It's the same with my stock tires when I replace them in the winter. Someone I knew had a same problem and it ended up being the steering pump. I'm not sure, real confused.
Old 08-26-2010, 10:22 PM
You didn't answer if the pump whines? If not, I would think the rack & pinion might be the stiff steering problem. Does it steer harder like in the morning on a cold start up, then get easier as it warms up? That's what they call "morning sickness". If so, it's your rack.
Old 08-26-2010, 10:24 PM
libertyforall1776's Avatar
Well you first checked you PS fluid, and it is at the right level?
You got the car from a shop and that happens? I would bring it back and ask them to tell you what's up at no charge -- I would have thought they would road test on a highway after alignment...
Old 08-26-2010, 10:54 PM
What do you mean by "pump whine?"
Old 08-26-2010, 11:05 PM
This blows, I'm selling this and picking up a SS.
Old 08-26-2010, 11:14 PM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
Pump whine, like it sounds like a supercharger when you turn. Could indicate low ps fluid. What kind of bushings did you use when you repleaced your suspension
Old 08-26-2010, 11:31 PM
my pump was bad and didnt whine. 6 month old pump. these pumps have a relief valve that lets fluid through after a certain pressure so you have the same presure from idle to wot. if it sticks open like mine it felt like the belt was slipping but only below 1500rpms. i changed the belt with no change. called a guy about a performance pump and he told me it was that relief valve. changed the pump and it is like new. it changed the way the car handled as steering was a little stiffer at higher rpms but at idle is was really hard to steer like the motor was off.
Quick Reply: Got everything installed but still rides the same......
