GM T-56 applications
Old 10-11-2007 | 06:57 PM
FIERO's Avatar
Default GM T-56 applications
hello
does anybody have information or knowledge about a T- 56 out of a 1999 camaro and bolting it up to a 2007 4.3 liter v6??
thanks
Old 10-12-2007 | 05:27 AM
squisher's Avatar
Default RE: GM T-56 applications
It's all in the bolt pattern and starter location really, do you know if the 4.3 has the same bolt pattern as the GM 5.7 V8 (really just about any SBC)? I wouldn't be surprised if it does.
Old 10-14-2007 | 12:31 PM
FIERO's Avatar
thanks squisher
i do know the bolt patterns on the 4.3L is the same as the 350. so theres a good chance it will bolt in??
thanks again!
scott
Old 10-14-2007 | 01:18 PM
squisher's Avatar
Well, because of that, I'd say that it will have a pretty good chance. Sounds like it ought to bolt right up. Better make sure the starter is on the same side, but it most likely is, since most of the 4.3/4300 engines I know about are RWD configuration.
Old 10-14-2007 | 01:56 PM
FIERO's Avatar
awesome thanks very much.. the 5 speed trans im my 2007 silverado really sucks and i have the opportunity to install a 6 speed T-56.
again, thank you very much!
scott
