fuel pump question
Old Apr 1, 2012 | 02:25 PM
rachel11's Avatar
Default fuel pump question
2001 Camaro v6 127,00 miles 5-speed
My car has been running really rough. Very choppy when going up hills or accelerating hard. I have code P0300. I have changed the following parts: all sparkplugs and wires, air filter, fuel filter ( 1 1/2 years ago), and cleaned the MAF sensor.
Yesterday, i checked the fuel pressure. the readings were:
key on: 48, then drops to 44 and holds for 5 min
idle: 42
@ 2000 rpm: 40-42.
Are these pressures normal?
If no, what could be the problem?
Old Apr 1, 2012 | 05:00 PM
fuel pressure seems ok. have a look here and see if any of this helps. https://camaroforums.com/forum/gener...e-p0300-53531/
Old Apr 1, 2012 | 10:39 PM
rachel11's Avatar
My dad says fuel pressure should be between 52 and 60, Is he correct
Old Apr 2, 2012 | 12:14 AM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
Sounds like something wrong with the transmission if its only under hard load. Is the clutch ok?
Old Apr 2, 2012 | 12:42 AM
50 to 60 on the 3.8 is normal so it is a little low.
Old Apr 2, 2012 | 12:39 PM
rachel11's Avatar
at what pressure is it necessary to replace the pump?
Old Apr 2, 2012 | 12:54 PM
for the sake of piece with dad i would consider replacing the fuel pump. although it could be the fuel pressure regulator. did you try unplugging the fuel pressure regulator when you were doing the test to see if it changed.
Old Apr 3, 2012 | 07:26 AM
rachel11's Avatar
craby. I did not unplug the reg. Did not know to do that. I will try that soon. thanks
pcarollo
Sep 30, 2014 10:08 PM
krazymonkeys
May 16, 2012 12:13 AM
imafishingfred
May 6, 2011 06:08 PM
1997Z28
May 25, 2010 10:28 PM
camarofreak1990
Jun 26, 2009 12:48 AM
