fuel pump
Does any one have information on how to add the new fuel pump to the bucket? I have seen that you can pick up just the pump and screen cheaper than the whole assembly........1SG
i did it by cutting the glued/welded areas and taking it apart put a granatelli 255 in it and used a plastic welder to put it back together. its workin fine but after doin a bit of reading, if i were to do it again i would use a gm oem pump with the bucket.
| All times are GMT -5. The time now is 09:57 AM. |
