fuel injectors
will the fuel injectors from a 1998 z28 work on my car? my car is a 2000 v6 auto
RE: fuel injectors
They will physically fit, but will be a too rich at WOT without a PCM tune. Bigger injector do not equate to more power, unless you modified the engine to where it needs more fuel than the stock injectors can safely provide.
RE: fuel injectors
if you get a bigger injector like the z28 you will need a bigger fuel pump and **** like that i would stick with your stock one to be safe... that can have major concequences if something does happen.
RE: fuel injectors
cant stick with the stock stuff, cause in a few weeks my car goes in to the shop for a custom turbo set up, the turbo will take the places of the muffler like the kit they make for the vet, i have the turbo and piping just need to get the stuff for the oil lines.
