First question
Hey everyone, Pulling the motor on the camaro and got to looking at it and looks like it would be better to pull the motor out the bottom, rather than the top. I am pulling the tranny at the same time, oh it is a 96 3.8 rs camaro. Thanks for any help
Jeffrey, Southpaw40
Jeffrey, Southpaw40
I have taken 2 out from the bottom and at first, I thought, no way but after you can comprehend actually doing it, it is a pretty simple task. Depends on what equipment you have to work with. Google removing camaro engine and you will find a step by step process with pictures. Good idea to read through it to ensure you have everything you need and are familiar with where everything is located that needs to be taken out. I use to have the link. I will look for it. Good luck!
Thats what I was looking for. Thanks alot Osduck5. I think there are a few things I missed and a few things I took off that I did not have to take off. I am done wrenching for the night, so I will see if I can finish getting it out tomorrow night after work.
Thanks again, Jeffrey
