Engine problem.
I just got through replacing both head gaskets, lower and upper intake manifolds and all that fun stuff. After installing everything, I tried to crank it. It turned over, and cranked up fast, but seemed like it was missing out a little bit. Now when i try and crank it, it will run well (minus the slight missing out) and within' seconds die.
Any ideas as to what might be to blame? |
Any Engine Codes?
Originally Posted by GMDCAMARO
(Post 347682)
Any Engine Codes?
No idead why the second code appeared. |
Year? Motor? Most common issue is valve adjustment.
Originally Posted by Gorn
(Post 347695)
I hope its not valve adjustment, the reason why i had to do all that work on it is because when i was working on my car recently i dropped a bolt into one of the cylinders and it was stopping the valve from working correctly, i just assumed that after taking the bolt out that it would work. |
Did you check the spark plug for damage? Otherwise it is possible that either the valves or pistons or both got damaged by the bolt. This will cause bad compression and misfire.
Originally Posted by z28pete
(Post 347731)
You said you have two codes, but don't mention what they were. Unless the lights you speak of are what you are saying are the codes. From what I have read, Reduced Engine Power pertains to the electronic throttle not working. Low voltage would be from an alternator that isn't working. When are said lights on?
Originally Posted by 02StanGT
(Post 347748)
The lights came on when i was driving up and down a hill, then it died. |
Also the engine was doing a little bit of loud backfiring.
