Engine Problem...?
I was driving my 96 Camaro today, and when I was on the highway it started to feel weird. I'm not sure how to explain it, but it just didn't feel like it was driving right. It had rained and the road was slick which may have affected it, but I'm not sure. When I got home, there was a slight knocking noise (it definitely sounded different than normal when running) and the I could feel some vibrations
Any ideas what this could be?
well it could be many things. I would start with the main bearings. sometimes those would cause some vibrations. could be a rod knock. does the sound that it makes sound like its hitting metal on metal? then it could be a lifter tick. its hard to tell without actually seeing/hearing the problem.
Yeah, that could be it. It was sitting out in the rain today, and I was driving it in the rain. Sometimes if I'm walking around the driver side rear of the car (near the fuel door), I can smell gas. Maybe there's some leak or opening where water got in?
How does this answer help? That is why he asked the question.
To the OP. Is the Service Engine Soon light on? The gas smell near the gas tank (which you should only smell when fueling up) leads me to think something with the EVAP emissions equipment is malfunctioning. It can also cause the engine to "stumble", or feel as if something is wrong.
I've only noticed the smell once or twice, as I walked past the rear driver's side of the car. I never noticed any leaks or anything, but didn't take a good look.
When I first got it fixed, the engine light came on and we took it back to the shop, he said that it was something with the emissions stuff. I forget exactly what he said but after he fixed it, there hadn't been a problem
When I drove to work today, it really started acting up. It had a bad knocking sound and the oil gauge dropped almost all the way to the bottom.
When I started it up to leave work, about 8 hours later, the oil gauge shot up and the knocking sound was horrible. The whole way home it was making noise, mostly in the lower gears, and the engine would die if I had to stop at a stop light/sign.
