-   93-02 V6 Tech (https://camaroforums.com/forum/93-02-v6-tech-14/)
-   -   Engine Noise (https://camaroforums.com/forum/93-02-v6-tech-14/engine-noise-15074/)
Berglar Jun 3, 2007 09:40 PM
Engine Noise
hi there, i'm new around here but am glad to say i'm a camaro owner myself, although it's a v6 automatic it gets the job done. i have a question about my engine, ever since i got the car a year ago i've noticed a high pitched whining noise coming somewhere around the alternator. i know it's not the alternator cause i've had it replaced under warranty and it didn't fix the problem. just curious if anyone else here has experienced the same noise that i have and have found a solution to it cause it gets on my nerves, lol. thanks!
[align=left] [/align]
GRIFF Jun 3, 2007 09:48 PM
RE: Engine Noise
I have the same thing going on with a dodge van I replaced the alt now the are saying its the belt tensoner
Berglar Jun 3, 2007 09:57 PM
RE: Engine Noise
yah they said it was my idler belts or something but that wasn't it either, i thought it might have been the air intake but it's not. idk where to look next
z28pete Jun 3, 2007 11:07 PM
RE: Engine Noise
Stick a a 3ft piece of garden hose to your ear and probe around the engine with the other end till you locate the noise. Cheaper and easier than changing out good parts.
libertyforall1776 Jun 3, 2007 11:45 PM
RE: Engine Noise
Could be your serpentine belt (try the Goodyear Gatorback belt to replace it), or the water pump bearing going out -- it will make all kinds of odd noises...
sethscamaro01 Jun 4, 2007 02:57 PM
RE: Engine Noise
Ive had 3 camaros all with 3.8 s and everyone of them has had a whine, i found all of my power steering pumps were worn. I believe that they may have started whining due to excessive rpms.lol may want to run the car and take of the top to the pump and if the noise is louder when you do that then thats your sign. Or if ur unsure of that method just take a rubber hose and hold it to it and you should hear that too.
aklin Jun 4, 2007 10:13 PM
RE: Engine Noise
if it is the power stearing. it will make a louder noise when u turn the stearing wheel from one side to the other fast.
check your water pump thoe, try wiggleing the pully (it shouldnt move) and feel under it for coolent comming out of the weep hole
i had a gtp that was squeeling from the power steering, and i just had it flushed and it fixed the pblm
Berglar Jun 4, 2007 11:11 PM
RE: Engine Noise
well i don't think it's the power steering cause it only makes the noise when i accelerate. i'll try using a hose to listen around when i get a chance tomorrow.
squisher Jun 5, 2007 02:48 PM
RE: Engine Noise
Got A/C?
Could be the compressor clutch, my old Cavalier did that, but strangely when I would turn on the A/C it would go away (The parts would stop moving relatively to each other kinda thing).
Turns out it just needed adjusted instead of replaced, like $45 at the stealership. (Granted, that was on a J-body before I had my F-body)
