Dyno Question and others
RE: Dyno Question and others
ORIGINAL: TotalChaos
Hey thanks RS96LSU. What type of lights will i need to get? And do you like them in your car?
Yeah i checked that out. But i didn't know if anyone had that done on a stock 3.8 then they tuned it to get lets say a better air fuel ratio to gain some extra HP or mpg.
I would swap your drums for discs, find a kit on ebay - it's not hard, just takes time did it on my '95.
Also, I believe if you swap a 98+ radiator plastic support, you could switch to a whisper lid setup and underneath SLP CAI... Anyone done such a swap?
Otherwise the SLP one will be fine.
Yeah i would like to do a swap too but it still works so i see no need to do that. If i find out something is wrong with one of them then I will look into it more.
I'll probably get the SLP CAI.
I have my own tuning software and such, so I just use the dyno for numbers. I haven't really had time to mess with tuning much yet. I still need to go back to the dyno and see if they can getit to graph outright. The lights in the dash are all 194. If you want to use LEDs like some of us, I would suggest www.v-leds.com
#20
02StanGT- What kind of software do you use? If you ever get that done flow that information over this-a-way. I was reading up on your posts on the led's and such and i was confused as to how the colors worked. Like you got yours blue so that means i cant just buy blue led's and stick them in and it be blue...i have to change the gauges? And if i just replaced them with white led's then it would be close to the stock look?
