Drivers Side Window
So one day i come home from work and put the windows up when i tried to put the drivers side up it came up half way and stopped, after a few mins it rolled up all the way, this happened to me on several other occasions as well so i try not to screw with the window too much. every other electrical thing in the car is fine, courtesy lights, stereo, power locks. What could cause it? motor goin bad?
Yea most likely the motor. Mine does the same I pull it with my hand while i press the button. It wouldnt hurt to oil your regulator just in case. Thta helped mine alittle.
any idea how much that motor is?
30 to 60 bucks if you put it in yourself.
Thanks craby
| All times are GMT -5. The time now is 07:15 AM. |
