Dashboard problem
So i just got a 97 chevy camaro bout 8 months or so but i noticed a rattling sound everytime i accerlate and it is coming from the driver side rite behind the speedometer...i took out the radio to get a look on the inside but i wasnt able to find nething...i was wondering could the rattling noise becoming from the back of the engine or inside the dash? if either how can i fix it? Thanx!
RE: Dashboard problem
It's real easy to take apart your dash, in fact mine is curretnly taken out. I have a 94 and to begin you take the two screws underneath the stearing wheel out then the two bolts. Go over to ur glove box and take the 3 bolts off the side and one off the top, then you front pieces come off. Then it pretty simple from there, a bolt probably needs to be tightened or something. Best of luck
check the defroster
