-   93-02 V6 Tech (https://camaroforums.com/forum/93-02-v6-tech-14/)
-   -   Dash Lights out (https://camaroforums.com/forum/93-02-v6-tech-14/dash-lights-out-59315/)
Dice276 Feb 11, 2011 07:24 PM
Dash Lights out
So i put in a head unit in my camaro and now my dash lights wont turn in a all. i tryed hooking the dash illumination wire to one of my accessory wires but nothing happened. i dont know what to do. the fuse on the side of the dash is fine
Massey Feb 11, 2011 07:27 PM
Either you blew a fuse or you fried the resistor for the dash lights on your headlight switch. Or your lights have been dimmed all the way down.
Massey
Dice276 Feb 11, 2011 07:51 PM
well i checked the fuse on the side of the dash and it was fine. how do i check the resistor? is there any other fuses?
Chaotic94 Feb 11, 2011 07:53 PM
Originally Posted by Dice276 (Post 508267)
well i checked the fuse on the side of the dash and it was fine. how do i check the resistor? are there any other fuses?
Fixed that for ya ;)
And no there aren't any other fuses.
BasicConcepts Feb 11, 2011 09:14 PM
i had the same thing happen to my car it is a fuse i missed it like 3 times its a 5 amp on the side of the dash towards the middle of the fuse box
Dice276 Feb 12, 2011 07:56 AM
Okay. Thank you I changed the fuse and they work now. Would it hurt to put a 10 amp in to prevent it from blowing in the future?
BasicConcepts Feb 12, 2011 08:08 AM
yes if something happens again you could fry some wires and possibly start a fire
