-   93-02 V6 Tech (https://camaroforums.com/forum/93-02-v6-tech-14/)
-   -   crankshaft position sensor (https://camaroforums.com/forum/93-02-v6-tech-14/crankshaft-position-sensor-29980/)
crw2008 Jul 19, 2008 02:51 PM
i have a 95 camaro 3.4l v6.
I am cleaning up the wiring in the engine compartment.
I a reading some of the diagrams in the back of my haynes
repair manual and I see a plug diagram AND i also have a
plug for BOTH a crankshaft position sensor AND a crankshaft
position sensor hi resolution.
I know i have a crankshaft position sensor, but do I
also have a crankshaft position sensor hi resolution.
How do I tell which plug to plug into the crankshaft
positon sensor, if I only have one?
And also what is the differnce between the two?
z28pete Jul 19, 2008 08:08 PM
RE: crankshaft position sensor
The 24X (high res) sensor is located behind the front damper, helpscontrols clocking up to 2400 RPM. Uses a 3 wire connector: PNK, PNK/BLK, BLU/WHT
The 3X (low res) sensor is located on the side of the block near the center of the crank & picks up when the 24X sensor fades out , over 2400 RPM. Uses a 2 wire connector: YEL, PPL twisted pair.
The Cam position sensor is located on the front of the engine behind the water pump and tells the PCM when the #1 cylinder is on the intake stroke, used for injector timing, among other things. Uses a 3 wire connector: PNK, PNK/BLK, BRN/WHT
All 3 sensors work together to give the PCM information as to which cylinder is in which stroke, andthe engine needs all three to work.
crw2008 Jul 21, 2008 08:23 AM
stupid me. i read the diagram wrong.
once you mentioned the cam position sensor, i remembered the plug for it.
I just couldnt see it cause I thought the wires hooked up to the silenoid that the
2 plug wire hooks to and the 2 hoses.
thanks for the detailed explanation. appreciate the help.
