Cranking issue...
Old Oct 19, 2010 | 07:31 PM
Edd2001's Avatar
Default Cranking issue...
My Camaro cranks up normally when the engine is warm, but in the morning or after my engine cools down, it takes a couple turns of the key to turn it on. It will crank normally but not turn over until I let off the ignition and turn it over a second time. Any suggestions?
Yeah, I have checked and switched a battery, checked the battery and starter cables, checked my starter, also the coil packs and sparkplugs, I have also changed the oil pressure switch, and my fuel pump works (tried switching the key off and on a few times to check pump and still no fire).
Old Oct 19, 2010 | 07:57 PM
chsxfireems's Avatar
change your fuel filter recently?
Old Oct 19, 2010 | 08:41 PM
osduck5's Avatar
Check your fuel pressure and vacuum lines for leaks as well.
Old Oct 19, 2010 | 08:52 PM
Edd2001's Avatar
Ok, so im guessing its fuel lines and fuel that are causing the problem?
Fuel filter has been changed about a year ago, so i guess ill switch it out.
Old Oct 19, 2010 | 09:03 PM
osduck5's Avatar
Check it for any codes with a scanner before you go chasin rabbits, if you haven't already.
Old Oct 19, 2010 | 09:19 PM
microkid's Avatar
March 2011 ROTM
Technical User
so the engine is cranking, but not firing? maybe a passkey issue?
Old Oct 19, 2010 | 09:27 PM
Edd2001's Avatar
Passkey issue??? And yeah the engine cranks but doesnt want to fire right away, it takes a couple of turns to start and i dont want to end up messing up my starter or flywheel..
mikes68
Apr 7, 2013 08:22 AM
jrhyno
Feb 19, 2013 08:22 PM
91 Droptop
Jul 10, 2011 01:32 AM
CheVy_R0aRrR
Jun 2, 2011 11:15 PM
Sewperdave
Mar 30, 2010 10:13 PM
