-   93-02 V6 Tech (https://camaroforums.com/forum/93-02-v6-tech-14/)
-   -   Crank bolt removal (https://camaroforums.com/forum/93-02-v6-tech-14/crank-bolt-removal-74358/)
Chevy101 May 23, 2013 01:59 PM
Crank bolt removal
What kind of compressors do you guys use to remove the crank bolt. I have a 1998 camaro with the 3.8L
libertyforall1776 May 23, 2013 02:52 PM
2 Attachment(s)
GM has specialized tools for this (see attached photos):
Document ID# 206839
1998 Chevrolet/Geo Camaro
Crankshaft Balancer Removal
Tools Required
J 37096 Flywheel Holding Tool
J 38197-A Crankshaft Balancer Puller
Use J 37096 to hold the flywheel.
Remove the crankshaft balancer bolt.
Use the J 38197-A to remove the crankshaft balancer.
Important
Do not separate the crankshaft pulley from the crankshaft balancer. Service the crankshaft pulley and the crankshaft balancer as an assembly.
Invert J 38197-2 so the leg of the tool is facing away from the crankshaft balancer.
Install the silver screws J 38197-4 to the crankshaft balancer.
Turn J 38197-1 to remove the crankshaft balancer from the crankshaft.
Remove J 38197-1, J 38197-2, and J 38197-4 from the crankshaft balancer.
Camaro 69 May 23, 2013 03:20 PM
I've used this simple little trick before to remove a stubborn crank bolt, and it works like a charm.
No need to get under the car, no need for fancy tools.
Looks like I'm not the only one who knows this trick:
Chevy101 May 23, 2013 03:34 PM
I've already drained the oils and removed the water pump from the car
Camaro 69 May 23, 2013 03:50 PM
So what?
fbodyrs96 May 23, 2013 03:51 PM
then hold the flywheel and use a breaker bar, socket. its not that hard.
Chevy101 May 23, 2013 03:53 PM
It's not going to hurt the car trying to start it with no fluids in it?
Camaro 69 May 23, 2013 03:56 PM
No it won't hurt it at all. You're not trying to start the engine, just tap it over. Disconnect the ignition wire as a safeguard then.
libertyforall1776 May 23, 2013 04:45 PM
Cool trick. ;)
Camaro 69 May 23, 2013 05:10 PM
It works well, the starter motor exerts more torque than any hand or air tool you could use.
Make sure you get the socket seated square against the bolt, and if you can, turn the engine over clockwise by hand to put a pre-load on the breaker bar. This will help to prevent the socket from popping off the bolt head, and possibly rounding it out.
