Crank bolt removal
GM has specialized tools for this (see attached photos):
Document ID# 206839
1998 Chevrolet/Geo Camaro
Crankshaft Balancer Removal
Tools Required
J 37096 Flywheel Holding Tool
J 38197-A Crankshaft Balancer Puller
Use J 37096 to hold the flywheel.
Remove the crankshaft balancer bolt.
Use the J 38197-A to remove the crankshaft balancer.
Important
Do not separate the crankshaft pulley from the crankshaft balancer. Service the crankshaft pulley and the crankshaft balancer as an assembly.
Invert J 38197-2 so the leg of the tool is facing away from the crankshaft balancer.
Install the silver screws J 38197-4 to the crankshaft balancer.
Turn J 38197-1 to remove the crankshaft balancer from the crankshaft.
Remove J 38197-1, J 38197-2, and J 38197-4 from the crankshaft balancer.
Document ID# 206839
Tools Required
Important
I've used this simple little trick before to remove a stubborn crank bolt, and it works like a charm.
No need to get under the car, no need for fancy tools.
Looks like I'm not the only one who knows this trick:
Cool trick.
It works well, the starter motor exerts more torque than any hand or air tool you could use.
Make sure you get the socket seated square against the bolt, and if you can, turn the engine over clockwise by hand to put a pre-load on the breaker bar. This will help to prevent the socket from popping off the bolt head, and possibly rounding it out.
