Could faulty PCM cause starting problems?
Old Sep 21, 2011 | 12:18 PM
305_camaro's Avatar
March 2012 Ride of the Month
Default Could faulty PCM cause starting problems?
I have been battling hard starting from my 1995 Camaro with a 3.4L for some time now and so I was discussing this with a friend of mine. He seems to think that its my pcm. He had a van with the same engine that had a similar problem as well as a friends firebird of the same generation and a new pcm fixed it. I'm not too familiar with how the PCM works but I know it controls fuel.
I have changed the ignition system, fuel filter, and FPR. After it finally starts it smells of fuel. Just wanted to see if anyone could back up this theory before I purchase another one.
Old Sep 21, 2011 | 12:29 PM
ECM don't go bad that often. Have you checked for trouble codes. Hard starting is usually caused fuel problems or ignition problems. What have you checked so far?
Old Sep 21, 2011 | 12:36 PM
305_camaro's Avatar
It doesn't throw any codes, I checked the fuel pump for any electrical problems a month ago on my tech class and I'm about to go to autozone and rent a fuel pressure gauge to see if i have adequate fuel. What pressures am I exactly looking for?
Old Sep 21, 2011 | 01:30 PM
3800camaro's Avatar
Mid 40's to low 50's for psi. Have you done any mods to your car? Like cam or timing chain? How's the plugs, coils and icm?
Old Sep 21, 2011 | 05:08 PM
305_camaro's Avatar
Well I've done a head gasket on it a few months ago and it did it before then. It does seem sluggish at WOT though
Old Sep 21, 2011 | 05:41 PM
3800camaro's Avatar
did you adjust the valve back lash correctly? is your timing lined up perfectly?
Old Sep 21, 2011 | 09:31 PM
305_camaro's Avatar
I did everything according to spec, the timing chain should be correct being as I never changed it
Old Sep 21, 2011 | 09:48 PM
Have you tried priming the fuel pump before attempting to start? Turn ignition key ON & OFF several times, allowing a few seconds between cycles, then try to start engine. Stay off gas pedal. If engine starts up quickly, then the fuel injection system is losing pressure when the engine is off.
Old Sep 21, 2011 | 09:54 PM
305_camaro's Avatar
I have tried that and it doesn't prime the system enough to start right up. I appreciate all the help from you guys, I just hope to figure it out before the snow season comes
Old Sep 21, 2011 | 10:07 PM
3800camaro's Avatar
Test your fuel pressure then. You might have a bad fpr or fuel pump.
