-   93-02 V6 Tech (https://camaroforums.com/forum/93-02-v6-tech-14/)
-   -   coolant problems maybe... (https://camaroforums.com/forum/93-02-v6-tech-14/coolant-problems-maybe-67644/)
tacameron Feb 1, 2012 07:36 PM
I have a 1999 camaro 3.8 auto I notice that it was using coolant so I pressure tested it saw coolant making its way out the back of the intake so I replaced the intake with the steel gaskets instead of plastic I also changed the valve covers they were leaking. Seems now the coolant in the radiator leaks down about a inch below the flews is this normal or am i leaking/ burning coolant what could be the problem/s
BasicConcepts Feb 1, 2012 07:39 PM
pressure test it again. hows the oil look?
craby Feb 1, 2012 07:41 PM
so your losing coolant? so no coolant in oil? did you change both intake gaskets? upper and lower. probly be a good idea to do a compression test on all cylinders. could be a headgasket starting to go.
tacameron Feb 1, 2012 07:46 PM
i hope it aint the heads i was just there oil looks good I will repressure test it in the morning I replaced upper and lower
