Coolant Flush Question
I have a 94 Camaro V6 which has been verified by a mechanic as having a blown head gasket. He suggested that we try a gasket sealer prior to repairing it (high cost due to part of engine being under the firewall). I went to drain the coolant from the block and when I got the drain plug out, there appeared to be a plug in there. I have not pulled the knock sensor yet. Does anyone know if I can drain the entire block from the knock sensor? Or is there a beterr way to flush out the block like pulling the thermostat?
Thanks,
Hank
Thanks,
Hank
I've never really heard anything good about any stop leak products. I've readarticles statingthat ifit's possible to plug the leak, what's to stop it from plugging some of the smaller passages. I can't say whether or notit willruin your engine, as I have no idea how bad the head gasket leak is, and I've never use any of that stuff. I personally wouldn't use any. If you do decide to use some, and it works, please don't think it's completely healed and not get it fixed. You sound like you have the right idea about not using it for that long.
Thank you for your opinion. That is a good point how does this stuff know what to plug or not plug up. I hate to have the camaro sit, I hate even worse to ruin it. I am still getting quotes for repairs, I was considering this as a temporary solution, but now I wonder if it will cost more inthe long run.
I would give a stop leak a shot first, what do you have to lose?
I have used the powdered/metallic flakes type before with results. I recommend not using that "brown sludge with the pellets" stuff by Bars Leaks.
And as far as it plugging smaller passages...If a head gasket leak is paper thin or less, what passages inside the engine are smaller than that? None! The stop leak works by it accumulating and slowly packing up a leak. If you have a wide gap, such as a gasket being totally blown out, then I wouldn't go expecting a miracle fix with a stop leak.
fix it and be done with it. get yourself some tools, a dealer service manual like planejane has, a buddy and fix it yourself. head gasket cost is not that much, 150 bucks or so for what ull need, 2 or 3 hundred to get the heads done depending on what needs done. its the labor that costs. dont use the stop leak unless u have to.
