-   93-02 V6 Tech (https://camaroforums.com/forum/93-02-v6-tech-14/)
-   -   compression (https://camaroforums.com/forum/93-02-v6-tech-14/compression-51435/)
BasicConcepts May 6, 2010 09:29 PM
compression
i want to test my compression but dont know what i should be getting
z28pete May 6, 2010 10:01 PM
Per the GM FSM. "The lowest reading should not be less than 70% of the highest reading, and no cylinder should be less than 100 PSI."
BasicConcepts May 6, 2010 10:15 PM
thanx man
BasicConcepts May 7, 2010 03:15 PM
whats the max so i know what size gauge to get
z28pete May 7, 2010 06:40 PM
GM does not publish the max limit. Just get a gage for gasoline engine use, and it should cover just any engine. Diesel gages go much higher and can cost more.
BasicConcepts May 7, 2010 06:43 PM
i was planning on going to northern tool and getting a 200 psi i dont think it will go any higher than that if 100 is absolute min ant the car is 15 years old so im sure its not as high as brand new any chance anyone knows what the thread is on the plugs
