Coil Pack Resistance
What are the values of the primary and secondary resistance on the coil packs?
Also where do I measure the primary value? |
Primary resistance is .3 to .6 ohms.
Secondary resistance is 5,000 to 6,500 ohms. Primary resistance is measured across the holes on the bottom of the coil. Secondary resistance is measured across the points on top of the coil. |
Thanks. I'll check this out tonight when I get home.
No problem. Let us know what you find out.
Well, looks like they're all good. They were all the same at about 6.5k secondary and about 1.5 ohm primary. (i don't think all of them would be out of the range, so maybe our numbers are off)
| All times are GMT -5. The time now is 04:49 AM. |
