Clutch issues...
Alright guys here's, yet, another clutch thread. So I've driven 3 other v6 Camaros besides mine and the clutch on them always feels so much better than mine. It's kind of hard to explain but when I'm pushing my clutch down I can't feel in engaging (when the car is off). When I'm in theirs and I push the clutch down, I can actually feel the difference half way through pushing it down. Like pushing it down I feel resistance for the first part of pushing it down, then it's pretty easy to push down. Mine it seems like there's the same amount of resistance all the way to the floor, which is about medium. They're has a lot of resistance and then hardly any halfway down. Mine has not nearly as much resistance as theirs. Also my clutch slips... I was about to do a burn out today and I ran my rpm's up to 3500 and dumped the clutch and all I got was high rpm's and the car took off really really slow. Then as it got moving the rpm's dropped down to about 2000 and then the car took off fast. I could smell something burning right after this happened. So this is my question: Is it time for a new clutch??? And if so, should I get a stage 1 or 2 clutch rather than a factory style one since I race my car around town a lot???
Maybe this??
http://www.lmperformance.com/19320/14.html |
I have read thread for people that where unhappy with the spec stage two. I can not imagin the spec stage 1 is any better. Look for a center force duel friction clutch. I am not sure if they make one for the 3.4 but I have one in my 3.8 and I am loven it. Stock feel with 90% more holding power then the OEM.
Any idea what website I should look at?? What brands are good for clutches? I've never done anything with drivetrain before so yeah I'm kinda clueless. I know if I do replace the clutch, I want something that will out last the motor in my car (its at 180xxx). I do a lot of street racing and stuff too. A lot of burn outs. I need a STURDY clutch. Recommendations? Websites? Thanks!!
yea it sounds to me like you are in need of more than just a clutch. When you get uneven feel in the petal of a stock clutch then it is most likely the slave or master that is getting worn out. I would budget for them too.
Massey |
Gorn: is this what you were talking about?
http://www.jegs.com/i/Centerforce/183/DF504965/10002/-1 |
Originally Posted by Massey
(Post 458967)
Massey |
Originally Posted by Chaotic94
(Post 458971)
$370 is pretty steep when it doesn't come with the throwout bearing or the pilot bearing... I was thinking like $300-$325 for everything. Any ideas?
If your petal is solid all the way through you should be good with the hydraulic side of the clutch. I have never driven a new car that had uneven clutch petal travel, not even new Corvettes with dual load pressure plates.
Massey |
