Check Engine Light Problems
Did u make sure all ur wires are on tight and havnt burnt from the exhaust manifold? Also, are they on correct, meaning firing order.. and if there is a vacuum leak or line off, it will cause a problem such as this. Check all the work u did to ensure everything is ok.
