Check engine light 3.4 Camaro
you ran out of memory and i got one of them wrong so here they are. i think you can go to my photobucket and get a better copy.
[QUOTE=craby]
this is for the most part the same as the 4.3 only difference is they say to tap on the engine lift hook to see if you can set off the sensor.
[QUOTE=craby]
yes i did but when i tried to send the last picture it wouldnt let me and said you had to many messages in memory. i dont think the air pump will effect performance so im not sure what is going on with your system. it may be theres a power draw in that wiring or the air pump.
Crystal Craven
10-09-2013 02:45 AM
JTNKTZ
07-13-2008 09:57 AM
JTNKTZ
07-12-2008 11:31 AM
