Center Console
Does any one know how to remove the entire center consel as well as the piece that has the cigarette lighter that is directly under the radio? Also can anybody recomend a good how to book for the camaro?
you can get a haynes or chilton manual if you want.There is one bolt when you open the lid to the console, then there is two bolts i believe where the cigarett lighter is on the bottom.it varies by year
There is 1 bolt where the cd compartment is all the way to the back, kina hard to reach. and there are a couple of bolts in the lid part as well. the pieces are fit together so make sure you see all of the connections when you start to remove it.
