Catalytic Converter
Old Mar 5, 2008 | 12:30 AM
dto325's Avatar
Default Catalytic Converter
My catalytic converter for my 1994 3.4 liter is rattling and i was wondering if anyone had suggestions about either just taking it off and hollowing it out, or buying a high flow cat. I had replaced the catalytic converter within the past 2 years, but recently i put headers on, and was thinking that it might have caused the replacement regular cat to start rattling. any suggestions would be great!
Old Mar 5, 2008 | 10:30 AM
bluovlh8er's Avatar
Default RE: Catalytic Converter
too bad its only a 3.4........ on the 3.8 camaro, if you alone gut the cat you can race vipers, making about 395 h/p by just gutting the cat alone!
Old Mar 5, 2008 | 03:08 PM
buddywackos's Avatar
ORIGINAL: bluovlh8er
hahaha, i remember that guy.
but anyway, i wouldn't just take it off unless your state isn't strict about stuff like that. i live in kentucky, so most of the officers don't mind seeing as how all the hilljacks would still do it anyway.
Old Mar 5, 2008 | 03:22 PM
95slvrZ28's Avatar
Ok, we really need to start linking the new guys to this thread when we talk about it so we don't look like uninformed jackasses
https://camaroforums.com/m_1704/tm.htm
Enjoy that buddy, there's a lot of reading in there, you'll learn lots of stuff you never knew
If you have emissions tests you should probably go with a high flow cat, especially if you have the "sniffer" test. If you don't have emissions you can just put in a test pipe and be done with it.
Old Mar 5, 2008 | 07:27 PM
94Z28SHAKER's Avatar
most aftermarket cat's have a protecive shield over them, sometimestheyrattle from time to time, check that before anything, you might get lucky.
Old Mar 5, 2008 | 07:46 PM
6v49der's Avatar
Those two tools should take care of the problem
Mine rattles too thats why I suggest, ermm, "customization"
Old Mar 7, 2008 | 03:38 AM
EDGE's Avatar
when i bought my car it had been decatted, one of te first things i did was to order and fit a new cat (got mine from rockauto) and it sounds 100x better, without the cat it has a real nasty tone to it.... there again, this was pobaly amplified by the aftermarket exhaust on it... which is next on the list..
Old Mar 7, 2008 | 02:55 PM
blink18236dude's Avatar
hey dto325....i got a question. how did your headers turn out. i just got mine done and they were the biggest pain ever. i bought pacesetter headers, you get the same? let me know how much trouble you had
Old Mar 8, 2008 | 05:43 PM
libertyforall1776's Avatar
Just delete it -- the only reason to keep it is if you are subject to emissions testing -- then get a high-flow cat for better flow...
Old Mar 20, 2008 | 01:43 PM
jpepper's Avatar
no ****ing way you can make 400hp but cutting out the cat. You are full of **** blouvlh8er.
