car problems
I have a 96 camaro rs. I just replace the heads and the gaskets because the car had overheated. I change the milky oil out and put new oil and filter. I also put new plug and wires. I put everthing back together with new gaskets and now the car is running rough or mis fire. All coils are new. After putting water in the engine and letting it run rough nothing happen. When I push the gas it clears up but it mis when its idling. I check my oil afterwards and it was milky again. What could be the problem? Could it be a crack block?
Was water missing from the radiator after you filled it and run the engine? If so, you could have cracked block or intake/head gasket leak. Are you sure you got them torqued down properly? White smoke coming out the exhaust?
My son overheated his and when we had the heads test, one was cracked.
