car hesitates a WOT
RE: car hesitates a WOT
ya thats the sensor i though was out so i was in no hurry to replace it because i knew the cat wasnt bad, but apparently it was the first sensor the i need to replace. thanks for all the help!!
http://www.autozone.com/R,APP232827/.../addToCart.htm
this one will work right? im pretty sure its exactly what i need and autozone had great instruction on how to install it that i printed out
the link isnt working
heres the description i copied off of autozone
About this product:
Part Number:
15732
Weight:
0.4lbs.
Warranty:
1 YR
Application:
Sensor located before catalytic converter
Note:
Universal
4 wire; heated; 2 required
Pricing:
$59.99
but i only need one right?
About this product:
Part Number:
15732
Weight:
0.4lbs.
Warranty:
1 YR
Application:
Note:
Universal
Pricing:
$59.99
I'd stick with the ones that areO.E. type, asthey areready to be installed and plugged in. The "universal", as you can see in the picture, has you fit the wires in the connector.
Universal O2 sensors come without connectors, and you need to cut the connector off the old sensor and splice it to the new one. You will need to make a very good splice, the crimp type eventually vibrates loose and you have problems again.
thats what i figured so i found an o.e type
hows this look
Bosch / Oxygen Sensor
for a 1998 Chevrolet Camaro
[/align]
About this product:
Part Number:
13474
Weight:
0.25lbs.
Warranty:
1 YR
Application:
Note:
O.E. type
4 wire; heated; 2 required.
Pricing:
$65.99[/align]
hows this look
[/align]
About this product:
Part Number:
13474
Weight:
0.25lbs.
Warranty:
1 YR
Application:
Note:
O.E. type
Pricing:
$65.99[/align]
