Camaro v6 Missing?
#32
I am having the same problem as you. My fuel pressure was fine as well. I think you need the K9 Key or something to read the computer correctly since you have an OBII connector with an OBDI diagnostic. However, you will probably get no error codes anyways, I didn't. My mechanic is going to do a compression check and some other stuff next week, I'll let you know what the problem is. Oh and btw, your problem is going to slowly get worse.
#33
I love how enthusiastic you are lol.OP keep your head up the fuel psi seems right.Dont give up it will be some stupid simple lil issue and a compression test takes all of 15mins tops not hard to do and i would also do a leak down test aswell.
#34
I will do a compression test anyways, but as far as leak down whats that include?
#35
A leak down test is a used to check the condition of the engine by using compressed air into the cylinder and measuring the rate at which it leaks down/out. Leak down testing is basicly to see if you have any cylinder leakage alone(such as blow by)(if your rings are sealing correctly)and valves aswell.You can do the compression test by your self for cheap autozone has the rent a tool deal thank its 47bux use it take it back and get your money back but as for the leak down test if youve never done it or watched it done before i would let some one do it that has before for the best results.
CountTripula
09-17-2013 11:29 PM
