camaro 350?
this is what i do when do a rebuild on a small block
1-bore 30 makes it a 355ci
2-fit 10-1 flat top pistons
3-202 heads if you can find a sets if not after market 205 are nice
4- replace rods with a good set of racing go to your locate speed shop if you have one in your area if not go to web--jegs or summit will have what you need
5-nice set of headers and if you can with amount of room you have to work with 3in dual ex-if not 2-1/2
6-i like a tow cam -it will get you low end torque
7-eldbr--manifold and carb--i like this over holly cause holly i fell are better for high hp build motors
this set up gets up somewhere in the range of 325-375 hp
beleive me this is a nice street set up or off road
