A/C compressor switch fuse keeps blowing
Old Jul 19, 2010 | 10:31 AM
Originally Posted by shai one
Here is the fax number 406 791 7445. It's my brothers work and he will give me the fax as soon as it is sent out. Thanks for your help.
Done.
Old Jul 19, 2010 | 04:25 PM
shaione's Avatar
Default cruise control
Ok I received the schematic and I appreciate it. I talked to my mechanic and he told me that it probably has nothing to do with the ac compressor but the actual cruise control itself. I noticed a couple of times when using cruise control that it would disengage and I had to reengage it again. Finally the fuse popped and my cruise control went out. Would there be a reason y the cruise control would pop this fuse? I've had the car for over 10 years now and havent replaced the cruise control arm, but could this be the problem? Let me know when you can. Thanks again.
Old Jul 19, 2010 | 06:58 PM
Fuses blow because of overload. The problem could be due to a bad component or to a damaged wire touching ground or another wire.
Old Apr 21, 2016 | 01:42 PM
Anthony Joe WindyBoy's Avatar
My camaro is doing the same exact thing. Did anyone ever find out how to fix it or? i would love some ac right about now...
Old May 24, 2016 | 03:47 PM
well i found out what was blowing mine. There has to be some bare wire in my ignition area somewhere because everytime i tilt my wheel all the way down it shorts the fuse out. Does anything know how to take apart the ignition area so i can peek around for that wire?
Old Jun 13, 2016 | 02:15 PM
found the wire. Coated it and now now more shorts!
mikilla
Dec 8, 2014 11:07 PM
Phirewire
Dec 6, 2013 11:59 AM
izayuhgawd
Nov 21, 2011 09:24 PM
JL15689
Oct 15, 2009 10:37 PM
Tealcam
Sep 1, 2008 10:42 AM
