A/C compressor ? 3800 v6
I have one of the prongs broken off the A/C compressor where the wiring harness plugs into it. Looking at the compressor in the parts manual, it shows a part called the A/C coil that mounts behind the clutch assy. this part looks like it has the connector on it. Has anyone replaced this part before and if so, how easy is it to replace and what is the price of it. I hate to buy another compressor just because the connector is messed up.
man that stinks,had issues in the past where same kinda problem happened but different part.guess you'll just have to pull engine out ...lol!!never changed just parts in the ac compressor but might be just as easy(?) changing it all.at minimum clutch assy and not sure but think pulley is pressed on
