-   93-02 V6 Tech (https://camaroforums.com/forum/93-02-v6-tech-14/)
-   -   Burnt spark plugs?! (https://camaroforums.com/forum/93-02-v6-tech-14/burnt-spark-plugs-71497/)
IdriveDSM08 Sep 2, 2012 09:59 PM
Burnt spark plugs?!
So today i was pulling my 94 camaro 3.4 v6 motor and when i pulled my spark plug wires i noticed my plugs where burnt. Burnt so bad it burnt the white coating off the plug, the plugs wires and coils are all like 1000 miles old. any ideas?
craby Sep 2, 2012 10:26 PM
are you sure the plugs where sealing correctly. sounds like you have exhaust leaking there somewhere
Camaro 69 Sep 2, 2012 10:41 PM
Outside or inside part of the plugs?
IdriveDSM08 Sep 5, 2012 06:27 PM
the outside, the egr tube had a whole in it so im hoping thats what it is.
Gorn Sep 5, 2012 07:28 PM
You are talking about staining on the outside of the plug? Could be as you stated or staining from an oil leak. The porcelain on the outside of the plug should be fine to 1500 degs F. You got something outside of your engine that is 1500 degs how well you plugs hold up will be the least of your worries.
IdriveDSM08 Sep 5, 2012 11:07 PM
lol yeah it was just staining, from the egr tube over the #1 spark plug that made it look worse than it was
