Bosch replacement O2 sensors
Hope someone has the answer, no luck searcing for this topic in previous posts. I bought the recommended pre-cat O2 sensors for my 97 3.8.Upon inspection of the stock sensors I noticed that the plug was different. The stock plug is a 4 wire square configuration and the Bosch replacements (#15703) have a 4 wire flat configuration. Do I have the wrong sensor? or just the wrong plug configuration? Any information at all is welcome.
Thanks in advance, Chris
The sensors are the same. The Bosch catalog is probably wrong. Take them back & get the right ones. Irecommend either Denso or AC Delco, had many issues with the Bosch ones.
