ac compressor
Old 08-18-2008 | 01:44 PM
bond67's Avatar
Default ac compressor
how to i pull the ac compressor, ive got the three front bolts but it looks damn near impossible to pull the lines on the back off. also how many bolts holding this on? just the three or more in the back? how do i get to the **** in the back? yes there is no freon left in the system. thanks
Old 08-19-2008 | 08:29 PM
jp3ssp's Avatar
Default RE: ac compressor
I just pulled the compressor from my sons car and put in a new front seal. There is 2 bolts in the very back that you get to by extension over the motor mount. Make sure you get all the bolts in the front and take off the mounting plate on the front then you can see what is going on a lot better. You can pull the compressor out then take the lines off the back. There might be a ground wire to the block that you might have to take off also. Good Luck John
txchevyguy
08-12-2012 06:04 PM
jkeaton
07-17-2012 09:08 AM
jamesjunk
06-03-2009 09:26 PM
Quick Reply: ac compressor
