98 v6 Camaro hesitation
My car has an engine code for the EGR valve, cylinder 3 misfire, and a o2 sensor. Now before you bash me, I love this car, but it's starting to get very frustrating. The a/c won't blow cold and for some reason won't blow out the vents at all. The other controls work ok though. Things I've done is replaced the sensor that was bad and cleaned the EGR valve which was not carboned up at all. I was replacing the plugs and had to replace the plug wire cuz it was the cause of the miss fire. It still hesitates when it's cold, but gets better when it gets up to running temp. Vacuum leak somewhere? Coil pack problems? The a/c hasn't been checked for freon leaks yet so I don't know if the problem is the electric cooling fan or not. Any help is good help.
could be the vacumm that goes to the heater/ac controler is leaking or broke or unhooked.
Thanks Craby
Does the A/C compressor even cycle on when the air conditioner is turned on? There is a switch in the line that disables the compressor if the freon level gets to low.
Originally Posted by osduck5
(Post 417228)
Thank you! |
Did you replace the O2 Sensor, or check diagnostics on it with a scanner?
Originally Posted by libertyforall1776
(Post 418102)
HELP ME.................LOL |
see if this helps
http://www.obd-codes.com/p0442 |
LOL.... I drove it without a gas cap for a few weeks cuz I lost it at a gas station. Then I bought one for the car but it doesn't quite fit right, cuz I don't think it's sealing just right. Oh geez that might be the freakin prob with that code. I'll try a new cap my friend. Thanks again for the heads up.
yep these cars are sensitive, lol and if u dont get them what they want u know about it. hope its a simple fix for ya. :)
